- 23. Juli 2014
- 414
- 76
- 9-3 II
- 2004
- FPT
When the battery voltage in the key falls below a predetermined level the Saab Information Display (SID) will issue the following message:
”Remote control battery low. Replace battery.”
Press the CLEAR button on the SID to acknowledge this message. You must then replace the battery without delay to avoid malfunctions. The life of the battery is normally 4 years.Contact a Saab dealer to have the battery replaced.
Manual für 9-5I sagt aber nicht welche Batterie... aber die Batterie-Spezifikation für 9-3II müsste beim 9-5I zutreffen.
