Whether your dash pad is cracked, torn, rusty or just plain “beat up,” Just Dashes can bring it back to the correct factory original specifications through a process called Thermo Vacuum Forming. We take your original pad and strip off the old vinyl and foam as needed. We then build up the foam by hand with our new and improved high-density closed cell foam to meet all the correct contours and dimensions. The pad is then covered with the correct grain vinyl, which a higher quality then originally used. The application of the vinyl is referred to as Thermo Vacuum Forming. The vinyl is heated to become pliable and “sucked” over the contours of the dash. The vinyl is then cooled to set the shape and trimmed around the edges. Your dash pad is then expertly matched to your chosen factory or custom color. See our home page titled “How we do it,” for more information. Since we are using the same vacuum process originally used by the factories some thirty years ago, your dash pad will be as close to the original as possible.
