Page Time: 0.0637s
Memory: 9.5168 MB (Peak: 10.1289 MB)
Queries (10, time: 0.0032s, 5.0%)
  1. SELECT data_key, data_value
    FROM xf_data_registry
    WHERE data_key IN ('options', 'languages', 'contentTypes', 'codeEventListeners', 'deferredRun', 'simpleCache', 'addOns', 'defaultStyleProperties', 'routesPublic', 'routeFiltersIn', 'routeFiltersOut', 'nodeTypes', 'bannedIps', 'discouragedIps', 'styles', 'displayStyles', 'userBanners', 'smilies', 'bbCode', 'threadPrefixes', 'trophyUserTitles', 'reportCounts', 'moderationCounts', 'userModerationCounts', 'notices', 'userFieldsInfo')
    Run Time: 0.000367
    Select TypeTableTypePossible KeysKeyKey LenRefRowsExtra
    SIMPLExf_data_registryrangePRIMARYPRIMARY27 26Using where
  2. SELECT data_value
    WHERE data_key = ?
    Params: modLogCounts
    Run Time: 0.000168
    SIMPLExf_data_registryconstPRIMARYPRIMARY27const1
  3. SELECT cache_value
    FROM xf_permission_combination
    WHERE permission_combination_id = ?
    Params: 1
    Run Time: 0.000164
    SIMPLExf_permission_combinationconstPRIMARYPRIMARY4const1
  4. SELECT post.*
    FROM xf_post AS post
    WHERE post.post_id = ?
    Params: 1362672
    Run Time: 0.000566
    SIMPLEpostconstPRIMARYPRIMARY4const1
  5. SELECT thread.*
    FROM xf_thread AS thread
    WHERE thread.thread_id = ?
    Params: 61846
    Run Time: 0.000426
    SIMPLEthreadconstPRIMARYPRIMARY4const1
  6. SELECT node.*, forum.*
    	permission.cache_value AS node_permission_cache
    FROM xf_forum AS forum
    INNER JOIN xf_node AS node ON (node.node_id = forum.node_id)
    	LEFT JOIN xf_permission_cache_content AS permission
    		ON (permission.permission_combination_id = 1
    			AND permission.content_type = 'node'
    			AND permission.content_id = forum.node_id)
    WHERE node.node_id = ?
    Params: 5
    Run Time: 0.000596
    SIMPLEforumconstPRIMARYPRIMARY4const1
    SIMPLEnodeconstPRIMARYPRIMARY4const1
    SIMPLEpermissionconstPRIMARYPRIMARY35const,const,const1
  7. INSERT INTO `xf_session` (`session_id`, `session_data`, `expiry_date`) VALUES (?, ?, ?)
    Params: 82bd4035cb3874cd3e041f0089632693, , 1594217175
    Run Time: 0.000282
  8. INSERT INTO xf_session_activity
    	(user_id, unique_key, ip, controller_name, controller_action, view_state, params, view_date, robot_key)
    VALUES
    ON DUPLICATE KEY UPDATE
    	ip = VALUES(ip),
    	controller_name = VALUES(controller_name),
    	controller_action = VALUES(controller_action),
    	view_state = VALUES(view_state),
    	params = VALUES(params),
    	view_date = VALUES(view_date),
    	robot_key = VALUES(robot_key)
    Params: 0, , , XenForo_ControllerPublic_Post, Permalink, valid, post_id=1362672, 1594213575,
    Run Time: 0.000207
  9. SELECT title, template_compiled
    FROM xf_template_compiled
    WHERE title IN ('page_nav', 'post_permalink', 'modess_moderator_bar_mod_log_counts', 'wf_hook_moderator_bar', 'wf_revealer', 'waindigo_navigation_visitor_tab_joinusergroup', 'PAGE_CONTAINER')
    	AND style_id = ?
    	AND language_id = ?
    Params: 2, 1
    Run Time: 0.000226
    SIMPLExf_template_compiledrangePRIMARYPRIMARY60 7Using where
  10. SELECT title, phrase_text
    FROM xf_phrase_compiled
    WHERE language_id = ?
    	AND title IN ('advanced_rules')
    Params: 1
    Run Time: 0.000174
    SIMPLExf_phrase_compiledconstPRIMARYPRIMARY106const,const1
Included Files (123, XenForo Classes: 51)
  1. index.php
  2. library/XenForo/Autoloader.php
  3. library/XenForo/Application.php
  4. library/Zend/Registry.php
  5. library/Lgpl/utf8.php
  6. library/Zend/Config.php
  7. library/config.php
  8. library/XenForo/FrontController.php
  9. library/XenForo/Dependencies/Public.php
  10. library/XenForo/Dependencies/Abstract.php
  11. library/Zend/Controller/Request/Http.php
  12. library/Zend/Controller/Request/Abstract.php
  13. library/Zend/Uri.php
  14. library/Zend/Controller/Response/Http.php
  15. library/Zend/Controller/Response/Abstract.php
  16. library/XenForo/Model/DataRegistry.php
  17. library/XenForo/Model.php
  18. library/Zend/Db.php
  19. library/Zend/Db/Adapter/Mysqli.php
  20. library/Zend/Db/Adapter/Abstract.php
  21. library/Zend/Db/Select.php
  22. library/Zend/Db/Expr.php
  23. library/Zend/Db/Profiler.php
  24. library/Zend/Db/Statement/Mysqli.php
  25. library/Zend/Db/Statement.php
  26. library/Zend/Db/Statement/Interface.php
  27. library/Zend/Db/Profiler/Query.php
  28. library/XenForo/CodeEvent.php
  29. library/XenForo/Options.php
  30. library/XenForo/Link.php
  31. library/XenForo/Template/Helper/Core.php
  32. library/Merc/DonationManager/Listener.php
  33. library/Merc/DonationManager/Common/Listener.php
  34. library/Merc/DonationManager/Common/Base.php
  35. library/ModEss/Listener/Cog.php
  36. library/Tapatalk/Listener/LoadClassModel.php
  37. library/Asp/OnlineStatus/Plugin/Plugin.php
  38. library/sonnbPreventDoublePost/Listener.php
  39. library/WidgetFramework/Listener.php
  40. library/sonnb/XenGallery/Listener.php
  41. library/WidgetFramework/Option.php
  42. library/XenForo/Router.php
  43. library/XenForo/Route/Filter.php
  44. library/XenForo/Route/Interface.php
  45. library/XenForo/Route/ResponseSuffix.php
  46. library/XenForo/Route/Prefix.php
  47. library/WidgetFramework/Route/Filter/PageX.php
  48. library/XenForo/Route/Prefix/Posts.php
  49. library/XenForo/RouteMatch.php
  50. library/XenForo/ControllerPublic/Post.php
  51. library/XenForo/ControllerPublic/Abstract.php
  52. library/XenForo/Controller.php
  53. library/Brivium/AdvancedRules/Listener.php
  54. library/Brivium/BriviumLibrary/EventListeners.php
  55. library/Andy/ShowDeleted/Listener.php
  56. library/Andy/ShowDeleted/ControllerPublic/Post.php
  57. library/XenForo/Input.php
  58. library/XenForo/Session.php
  59. library/XenForo/Helper/Ip.php
  60. library/XenForo/Visitor.php
  61. library/XenForo/Model/User.php
  62. library/Waindigo/JoinUserGroup/Listener/LoadClass.php
  63. library/Waindigo/Listener/LoadClass.php
  64. library/Waindigo/Listener/LoadClass/20131003.php
  65. library/Waindigo/JoinUserGroup/Extend/XenForo/Model/User.php
  66. library/WidgetFramework/XenForo/Model/User.php
  67. library/sonnb/XenGallery/XenForo/Model/User.php
  68. library/XenForo/Permission.php
  69. library/XenForo/Phrase.php
  70. library/XenForo/Locale.php
  71. library/Waindigo/JoinUserGroup/Listener/ControllerPreDispatch.php
  72. library/Waindigo/Listener/ControllerPreDispatch.php
  73. library/Waindigo/Listener/ControllerPreDispatch/20140603.php
  74. library/Waindigo/Listener/Template/20140101.php
  75. library/Waindigo/Listener/TemplateHook/20130522.php
  76. library/Waindigo/Listener/TemplatePostRender/20130522.php
  77. library/Waindigo/Listener/TemplateCreate/20130522.php
  78. library/Waindigo/Listener/InitDependencies.php
  79. library/Waindigo/Listener/InitDependencies/20140401.php
  80. library/XenForo/ControllerHelper/ForumThreadPost.php
  81. library/XenForo/ControllerHelper/Abstract.php
  82. library/XenForo/Model/Post.php
  83. library/Asp/OnlineStatus/Model/AspPost.php
  84. library/ModEss/Model/Post.php
  85. library/sonnbPreventDoublePost/Model/Post.php
  86. library/XenForo/Model/Thread.php
  87. library/ModEss/Model/Thread.php
  88. library/sonnbPreventDoublePost/Model/Thread.php
  89. library/WidgetFramework/XenForo/Model/Thread.php
  90. library/XenForo/Model/Forum.php
  91. library/XenForo/Helper/String.php
  92. library/XenForo/Helper/Discussion.php
  93. library/ModEss/Model/ModEss.php
  94. library/XenForo/ControllerResponse/View.php
  95. library/XenForo/ControllerResponse/Abstract.php
  96. library/XenForo/Helper/Cookie.php
  97. library/XenForo/ViewRenderer/HtmlPublic.php
  98. library/XenForo/ViewRenderer/Abstract.php
  99. library/XenForo/Template/Public.php
  100. library/XenForo/Template/Abstract.php
  101. library/WidgetFramework/Core.php
  102. library/XenForo/Model/Moderator.php
  103. library/Waindigo/JoinUserGroup/Extend/XenForo/Model/Moderator.php
  104. library/ModEss/Model/Moderator.php
  105. library/sonnb/XenGallery/XenForo/Model/Moderator.php
  106. library/WidgetFramework/Model/Widget.php
  107. library/WidgetFramework/Helper/Sort.php
  108. library/WidgetFramework/WidgetRenderer.php
  109. library/XenForo/ViewPublic/Base.php
  110. library/XenForo/View.php
  111. library/WidgetFramework/XenForo/View1.php
  112. library/Waindigo/JoinUserGroup/Listener/TemplateCreate.php
  113. library/XenForo/Route/Prefix/Members.php
  114. library/WidgetFramework/Template/Extended.php
  115. library/XenForo/Route/Prefix/Threads.php
  116. library/Tapatalk/EventListener/Hook.php
  117. library/Waindigo/JoinUserGroup/Listener/TemplateHook.php
  118. library/Tapatalk/Listener/TemplatePostRender.php
  119. library/WidgetFramework/WidgetRenderer/Empty.php
  120. library/XenForo/Helper/Criteria.php
  121. library/XenForo/Debug.php
  122. mobiquo/smartbanner/head.inc.php
  123. library/XenForo/ViewRenderer/Json.php
